You used to be able to add a script to your start scripts using
Rhino.AddStartupScript Rhino.LastLoadedScriptFile
With Rhino 6 this causes an error.
Does this still work and what do I need to do differently?
Thanks Mark
Thanks Mark
Hi @Hughes_Tooling,
The attached seems to work. Perhaps you can provide a sample that doesn’t?
SineWaveSrf.rvb (1.1 KB)
– Dale
Hi Dale
This seems to be working fine now so not sure what the problem was before. If I see it again and can figure out the steps I use if I get an error I’ll post again.
Thanks Mark
