Editing Rhino Options from Python - Run Command on Startup
Hi all,
I’d like to have a Rhino command run every time Rhino starts. I know that I can manually add the command here in options:
But I want to add the startup command from a Python script (or rvb script). I am implementing this change on many users’ machines and would like to have the startup commands added or removed from a script.
I saw on the forums how to update the PackageManger source setting in python:
settings = Rhino.PlugIns.PlugIn.GetPluginSettings(Rhino.RhinoApp.CurrentRhinoId, False)
s = settings.GetChild("Options").GetChild("PackageManager")
s.SetString("Sources","https://yak.rhino3d.com;" + packageFolder)
But I cannot figure out how to adapt this code to edit the startup commands. Can anyone help?
Thanks!
there is a lot of info in this old topic:
Thanks for the reply - I had read through that topic before posting but unfortunately it does not answer my question.
They discuss how to make .RVB scripts run at startup but what I want to do is to script adding a command to options to run at startup.
rhinoscript can:
StartupScriptCount
Returns the number of startup scripts.
StartupScriptList
Return the list of startup script files.
AddStartupScript
Adds a startup script to RhinoScript.
DeleteStartupScript
Removes a startup script to RhinoScript.
my guess is, if you add a file with .py this will also run.
You might also workarround by calling a command of a custom (your) (rhinocommon) plug-in.
rhinoscript is directly accessing the c++ sdk methods.
phyton and rhinoscriptsyntax are based on rhinocommon.
image from here
there might be difference of what is accessible.
i never tried, but you might also be able to add a startup script using a macro.
starting with
!-_documentproperties _options
because of this thread i think @stevebaer might be the right person to answer your question with more details / options / alternatives.
Thanks Tom_P!
I couldn’t get Rhino to run a py script from the startupscriptlist but thanks to your links I came up with a bit of a clunky workaround that is doing what I need.
If it helps anyone in the future: I have an .RVB script that calls the command that I want:
Option Explicit
Sub WakeUp()
	Dim commandName
	commandName = "GoodMorning"
	Rhino.Command commandName
End Sub
WakeUp
I am using another RVB script to add the initial script to the startup script list, I would have preferred to do this with python but I could only access AddStartupScript through RVB:
Option Explicit
Sub StartupEnable()
	Dim filePath
	filePath = "C:\my file\path here\WakeUp.rvb"
	Rhino.AddStartupScript(filePath)
End Sub
StartupEnable
I can then finally call the StartupEnable script from python to add the command to the startup script list:
scriptPath = r"C:\my file\path here\StartupEnable.rvb"
Rhino.RhinoApp.RunScript("-LoadScript " + scriptPath, True)
If it helps anyone, there is a way to add startup commands purely in python without that clunky RVB step. Here is the function I now use to add startup commands
def addStartupCommand(str_cmd):
    '''Adds a new command to the startup command list.'''
    addedCommand = False
    try:
        if str_cmd:
            str_cmd = str_cmd.lower()
            # Get settings for startup commands
            rhino_id = Rhino.RhinoApp.CurrentRhinoId
            settings = Rhino.PlugIns.PlugIn.GetPluginSettings(rhino_id, False)
            settings = settings.GetChild("Options").GetChild("General")
            # Fetch existing commands and add if not present
            commands = settings.GetString("StartupCommands").splitlines()
            if str_cmd and str_cmd not in commands:
                commands.append(str_cmd)
                settings.SetString("StartupCommands", "\n".join(commands))
                addedCommand = True
    except Exception as e:
        try:
            print("Error in addStartupCommand: " + str(e))
        except Exception:
            print("Error in addStartupCommand: An unknown error occurred.")
    return addedCommand
And here is the function to delete them
def deleteRhinoScriptStartupScript(path):
    '''Removes a script from the RhinoScript startup script list.'''
    deletedPath = False
    try:
        if path:
            path = path.lower()
            # Get the RhinoScript plugin object
            rhinoScript_Id = Rhino.PlugIns.PlugIn.IdFromName("RhinoScript")
            rhinoScript = Rhino.RhinoApp.GetPlugInObject(rhinoScript_Id)
            # Remove the script if it exists in the startup list
            if rhinoScript:
                startupList = rhinoScript.StartupScriptList()
                if startupList:
                    for script in startupList:
                        if script.lower() == path:
                            rhinoScript.DeleteStartupScript(script)
                            deletedPath = True
        try:
            print("Error in deleteRhinoScriptStartupScript: " + str(e))
        except Exception:
            print("Error in deleteRhinoScriptStartupScript: An unknown error occurred.")
    return deletedPath
Nice one. How do you find coding in Python now, compared to RVB?
I might not be the right person to ask since I started coding in python :wink: but I prefer coding everything in python. Especially since the ScriptEditor doesn’t support RVB
