Hello there,
I’m currently using gh in rh7 by rhino.inside.
I installed several add ins and everything worked fine.
Yesterday I wrongly installed a package by the package manager, that package was already placed in the “Libraries” folder so I had an ID conflict issue.
After I solved that issue #SnappingGecko disappeared from gh.
I tried several times unistalling/installing that package both with #PackageManager and copy pasting in Libraries folder with no results, any suggestions?
EDIT:
actually in preferences I see the SnappingGecko settings
I’m using it with no issues, Rhino 8 fully updated on Windows 10 fully updated
close Rhino
check these two locations on your HD:
C:\Users\your_user\AppData\Roaming\Grasshopper\Libraries
here are the Libraries you install by hand by downloading the file from food4rhino
if you have a snappinggecko.gha file there: delete it
then go to:
C:\Users\your_user\AppData\Roaming\McNeel\Rhinoceros\packages\8.0
here are the Libraries you install through Packagemanager in Rhino
if you have a folder named SnappingGecko delete it
reboot PC because it’s beautiful to do it sometimes
after fresh reboot start Rhino, and confirm you don’y see any SnappingGecko options/setting anymore
if that is the case (if you don’t see those settings anymore) then you are clean and you can install it from PackageManager and it should work properly
after cleaning both the directories, did you open Rhino and GH to check that you would not have anymore SnappingGecko options available in your GH Settings?
EDIT: at a certain point snapping gecko and other components previously grayed out or diasppeared, were again fully functionant no idea what happend.
Then I installed a new component Pangolin (don’t remember if via “component folder” or “package manager”) and again some components disappeared from grasshopper interface and now they are still not running.
I uninstalled rhino and the add ins (both installed by package manager and by libraries folder) and I reinstalled them one by one.
I discovered that snapping gecko disappears once I install pod_gh_button, if I remove this add in snapping gecko returns fully operative so that is the conflict.
Anyone who noticed this same specific conflict? Is there any solution?
Because you know pod_gh_button is quite usefull so it would be sad not being able to use it.
