Hi all, do we have an “Add curtain system” button in RIR? If we have, how can we use it with predefined curtain grid lines in Rhino?
What I want to do is to add some horizontal aluminum panels with none equal grid lines(as shown)
Thanks
Hi Jack_Zeng,
We do have a feature request for ‘By Face’ Curtain System components, but no native components at this time.
I see, thanks. I wonder if there is any alternative ways to achieve this…cos I am not going to create a new curtain system. I just want to apply an existing curtain system on a new massing. I wonder if there is something like “add component family” can load an existing curtain system family on to a new massing.
you can switch out the type of your existing Curtain System with the Element Type component.
Hi @遲了悔改
I believe not every wall type is compatible.
You can run a quick check using the following method
collector = FilteredElementCollector(doc).OfClass(WallType).ToElements()
valid_wall_types = []
for wt in collector:
try:
if DB.FaceWall.IsWallTypeValidForFaceWall(doc, wt.Id):
valid_wall_types.append(wt)
except Exception:
pass
valid_wall_type_names = [wt.Name for wt in valid_wall_types if hasattr(wt, "Name")]
Yeah…. found that out the hard way …. I swap to create a slanted wall with profile instead of wall by face which doesnt do curtainwalls.
