Add Control Point Distribute Feature
RH-70352 is fixed in the latest WIP
outstanding! thanks…
already having a lot of fun with this!!! Now, the extension to this, is the notion of distributing along a curve. i.e. I have a set of points and a curve “path” (along an x,y,z path). I snap the points I want as the outside extents of the distribution on the Curve “Path” and the inner points distribute along the curve “Path” between those extents. I guess the default would be to distribute all the points the full length of the curve “Path”. Does this make sense?
I use that with align->ToLine and after that Distribute->Direction.
I don`t know how to use it on a curve.
Is it possible to use it on a curved arch because I can see only x,y,z and straight direction of distribution without the possibility of using a curve?
How to use that distribute to points and maintain the arch shape?
