is there any component other than “add Aligned Dimension” in RIR to use to dimension between a rebar and a line?
The component works between lines but what if we have a circle that we want to dimension to the center and a line?
Thanks in advance for your help!
@afshin_shafa you can use Add Linear Dimension. for Detail items you can check the following
