Due to unknown reason, the “Adaptive component by points” seems not work, and red warning “value can not be null”.
Can someone please tell me is this a bug? or how should I correct the connection?
Environment: win 10 rhino 7.7.21 revit 2021
system language Chinese (simplified), but I tried to turn rhino and revit language setting into EN-us, neither.
I did nothing in Revit and just create an ordinary dual-curve surface which is picked up in grasshopper at the very beginning in the file that I uploaded.
It’s doesn’t matter which kind of surface you can replace, just can not work and generated empty data.
I meet the same problem too, the message in red ballon is“ 1. RhinoInside.Revit.GH: Value cannot be null”.
And it seems this component always cannot work, no matter which family I choose.
Hi, I have just encountered the same problem which brought me to this page. “Add Component (Adaptive)” did not work with families or generic model because the item selected in “Type” has to be adaptive with points. After modelling manually in New Family > Metric Generic Model Adaptive, then “Load into Project”, the Grasshopper script worked for my case. The tutorial below has really helped.
