I have been attempting to control the print functions in Rhino using C# and not having much success. My most successful attempt to date involves creating a custom class that which defines all the options available to me through the “-_Print” command line. Once an instance of the class is initialized I can assign values to the properties depending on how I would like the current layout to print. Finally by calling the RhinoPrinter.Print() function I am able to create a very long string which is then passed into RhinoApp.RunScript to run the string through the command line and assign all the printing setting I need and finally press Go.
This method has many issues, changing scales in when setting a ViewportArea=Window will pop up a dialog box that I cannot close via RhinoApp.RunScript, there is no way to change from portrait to landscape page modes. After perusing the forums a bit I have come across several other people that are having a similar issue, but none with a workable solution. Is there some way I have have not yet considered to access the functions of the print dialog?
Below is the C# class to script the -_Print command:
public class RhinoPrinter
public RhinoDoc Doc { get; set; }
public Rhino.Display.RhinoPageView PageView { get; set; }
public string Printer { get; set; }
public Tuple<double, double> PageSize { get; set; }
public double PageWidth
get { return this.PageSize.Item2; }
public double PageHeight
get { return this.PageSize.Item1; }
public UnitSystem Units { get; set; }
public string ViewportArea { get; set; }
public string OutputType { get; set; }
public string OutputColor { get; set; }
public Tuple<double, double, double, double> Margins { get; set; }
public bool Preview { get; set; }
public RhinoPrinter() { }
public RhinoPrinter(RhinoDoc doc, Rhino.Display.RhinoPageView pageView, string printer, double printHeight = 11, double printWidth = 17)
this.Doc = doc;
this.PageView = pageView;
// default setting for the printer //
this.Printer = printer;
this.Units = doc.PageUnitSystem;
this.PageSize = new Tuple<double, double>(printHeight, printWidth);
this.OutputType = "Raster";
this.OutputColor = "DisplayColor";
if (printHeight == 8.5 && printWidth == 11)
{ this.ViewportArea = "Extents"; }
else { this.ViewportArea = "Window"; }
this.Margins = new Tuple<double, double, double, double>(0, 0, 0, 0);
this.Preview = false;
public void Print()
string cmd = "-_Print ";
// enter Setup menu //
cmd += "Setup ";
// enter Destination menu //
cmd += "Destination ";
// set printer //
if (string.IsNullOrEmpty(this.Printer) == false)
cmd += string.Format("Printer {0} ", '"' + this.Printer + '"');
// set page size //
if (this.PageSize != null)
double width = 0;
double height = 0;
if (this.Units == UnitSystem.Inches)
width = this.PageWidth * 25.4;
height = this.PageHeight * 25.4;
if (width > 0 && height > 0)
cmd += string.Format("PageSize {0} {1} ", width, height);
// calibration scale should always be 1 //
cmd += string.Format("CalibrateXScale {0} ", 1);
cmd += string.Format("CalibrateYScale {0} ", 1);
// set display type (raster or vector) //
if (string.IsNullOrEmpty(this.OutputType) == false)
cmd += string.Format("OutputType={0} ", this.OutputType);
// set display color (print, display BW) //
if (string.IsNullOrEmpty(this.OutputColor) == false)
cmd += string.Format("OutputColor={0} ", this.OutputColor);
// exit Destination menu //
cmd += "_Enter ";
// enter view menu //
cmd += "View ";
// set view output scale //
cmd += string.Format("Viewport {0} ", PageView.PageName);
// set viewport area //
if(this.ViewportArea == "Window")
cmd += string.Format("ViewportArea=Window 0,0,0 {0},{1},0 _Enter ", this.PageView.PageWidth, this.PageView.PageHeight);
else if (this.ViewportArea == "Extents")
cmd += string.Format("ViewportArea=Extents ");
// exit view menu //
cmd += "_Enter ";
// set margins //
if (this.Margins != null)
cmd += "Margins ";
cmd += string.Format("LeftMargin={0} ", this.Margins.Item1);
cmd += string.Format("RightMargin={0} ", this.Margins.Item2);
cmd += string.Format("TopMargin={0} ", this.Margins.Item3);
cmd += string.Format("BottomMargin={0} ", this.Margins.Item4);
cmd += "_Enter ";
// exit Setup menu //
cmd += "_Enter ";
// set auto printing setting //
if (this.Preview) { cmd += "Preview "; }
else { cmd += "Go "; }
RhinoApp.RunScript(cmd, false);
