I’m looking to access dimension text overrides using Grasshopper.
The script I’m working on uses Heteroptera’s Pick Objects (which outputs the selected object’s GUI) and I use that to create aligned dimensions. What I want is to override the dimension text and read the changes with Grasshopper so I can move my wall lines by the difference between the two.
Though where do I access this value? In Rhino it is under the text settings, but in Grasshopper there’s no socket for it.
