wb irregular bumped surface.gh (18.3 KB)!
irregular bumped surface.ghuser (10.5 KB)
I created a .ghuser for this pattern. May it could make your work a tiny bit more convenient.
The output is a mesh surface.
It requires Weaverbird and Lunchbox to be installed.
can you help me to do this
what do you need help with?
texture displacement using pattern image
Hello @ahmed_hamdan please make a new topic, where you start with a clear description of the end result you are aiming at, with reference images, a sketch and the things you’ve tried so far in Grasshopper and / or Rhino.
