A question about array polar
With array polar, the program asks you to specify the number of objects, but if you don’t know how many will fit in your circle is there any way to have the program figure it out? Anotherwords, you select the object you want to array in to a circle, then tell it you want to fill 360 degrees and let it figure out how many it needs?
Then there is the gap between them…
Any ideas would be appreciated.
Hi Cosmas- As is, you can preview and change the number of objects until it looks right before accepting the result… not good enough?
I’m sorry, Pascal, the preview didn’t seem to be working – at least the way I’ve been using it. Let me try that again.
Got it: ) It works. Thank you.
