A negative value for the Mask syntaxes
Is it possible to use a negative integer for the Mask of the Split Tree component for instance as it is possible for the List item component? For instance, I’d like to get this result; {*}[(<3)or(>-3)], but seems the mask doesn’t accept negative value. Or there is only the Path Statistic component that can help, but it’s not the convenient way at all…
This works
@martinsiegrist First of all, thank you for your reply, but I know about the Path Statistic comp, you don’t get my question, I want to get this logic like this {*}[(>=-3)] which means for any path, want to get three last items
Please upload here a sequence with tree data. :arrow_up_small:
@eddi
Mask.gh (8.2 KB)
Mask_re.gh (14.3 KB)
@HS_Kim Thank you! It is a solution indeed but workaround solution, seems there are no possibilities to use simple syntaxes for Mask
Can this work ?
MaskFaL
MaskFirstaLast.gh (7.8 KB)
This also works…
Mask_reV2.gh (15.1 KB)
@eddi Neat solution as well
I appreciate the string manipulation component :grin:
MaskFLwTfrm.gh (11.4 KB)
Just for fun:
a = x [y: -y:]
del x[y: -y:]
b=x
@martinsiegrist Yea, maybe the simplest solution :grinning:
@DavidRutten are negative numbers for the SplitTree going to be implemented in GH2?
