So TextTag might be my least favorite text component but it’s the only one I know of that displays text oriented to your view. Really useful for quick snap shops for construction drawings, or it would be, if you could increase the relative scale more easily. I know you can right click and use a preset for all input text but that feels clunky and imo doesn’t really do much when the scale is so dependent on your zoom. I end up having to change the scale of multiple text-tags independently to get different perspectives.
Also, what you see doesn’t often transfer to printing documents, images or PDFs the same, and I have to screen capture at a lower resolution.
Is there a trick to this, or another plugin/component I could try instead? I sometimes use other text components with the surface normals, that will at least put everything on the right plane but not a great rotation. Nothing beats text that rotates with you, especially for recording videos.
