Hello there,
I have some problems with the 6Dof beam components.
In the first figure, with the start&end node connected to the frames, it can be managed to locally twist the beams. However, the beams are not connected as one system.
In the second figure, with the start&end node disconnected to the frames, the beams are effected each other and they become one system. However, the local twisting didn’t work.
Is there a solution to do both local twistings and combine the beams as one system? @DanielPiker
I post my document here in case anyone is interested in it. Thank you in advance!!!
6DOF beam.gh (25.1 KB)
