Hey There Guys i was just wondering whats the best Format to export a 3dsmax file into Rhinoceros?
Thanks
it is what you are defining in being the best depending on what you want to do and what files you are importing, is it Mesh, Nurbs?
In Mesh format ofcourse, i never knew 3dsmax files can be used as a nurb object in rhinoceros…
but if thats possible please let me know.
i dont use 3ds max but i believe it outputs 3dwg, if you want to try and get nurbs over that could maybe function? dwg should also work for mesh anyway. otherwise obj might be the way to go.
unfortunately your sparse explanation does allow for a lot of guessing. did you succeed in any export at all or is it just a rhetorical competition that you can sleep better at night knowing you did the best ![]()
very funny i exported it using dwg and it worked best, i was actully wondering if there was a better way beacuse the model was bigger in size and the mesh a bit difficult to edit in.
But thanks anywways. ![]()
From my experience it’s either dwg or stl.
