3D to 2D With unroll?
Unroll.3dm (709.2 KB)
Hello
I would like to “Unroll” the Purple surface to 2D. Unroll-, not project to 2D.
Can somebody tell me how I can do this?
Kind regards
Filip
Hello
Thank you for your help. I have seen the helpfunction and tested it before my question.
What I would like is to Unroll the hole purple surface to 2D in one time. Because otherwise it looks like every surface will be at a different location. Maybee I first have to make all the purple surfaces to one surface, but I don’t know how I have to do that.
@Filip_Mangelschots would this help? https://youtu.be/igxfGSmImWo?t=138
farouk.serragedine@gmail.com
This looks really nice, but I would like to unroll all the purple surfaces at ones so they won’t move away from each other. It is also ok to do this in several times, but they have to have the same reference to each other. I would like to have an exact 2D from the purple 3D-surfaces.
Hi @Filip_Mangelschots
Are you asking to unroll all the purple surfaces, meaning the base surface AND the trimmed surfaces in one go? If yes, you can use Flow instead of UnrollSrf. DupEdge the curved edge of the base surface, create a Line of the exact same lenght as the edge, use Flow with the edge as the base and the line as the target.
HTH, Jakob
@Normand Thank you! This is exactly what I need.
My problem is solved.
