Well, as symmetrical as the node counts allow, “yes”. What you are asking for is essentially what I mean when I say you’d need a better branching system; one that does not crudely simply pick the next closest point via the geometry, but trys to allocate the branchings in a rung as evenly as possible in the full 360 degrees, WHILE taking into account where the branchings are placed in the rung preceeding it. This way you get more “straighter” lines all over the shape.
But that takes thought end energy. And possibly recursion which is tough without Anemone. Maybe someone can think of a cheap solution?
Reading through this script right now. Wanted to try an attempt to apply the same logic to a surface/mesh instead of a curve, in the case the profile changes throughout. A challenge!
Edit: Apparently, if I am given to understand correctly, this kind of phase shifting is standard when doing point sampling, anti-aliasing, etc.
The real thing I think is actually knitted in a spiral, so really you wouldn’t be working with rungs, but I don’t know how to get a spiral on the surface with constant gain, i.e. even spacings between the winds. @laurent_delrieu
Hi all.
Posting a failed approach (heavy, slow, no control over result)…
I’ve made a custom goal for kangaroo starting from this:
which will try to keep a plane oriented to a surface and rotated about a specific angle from U isocurve direction.
This + plus each frame is a rigid set of points + sphere collide:
PS
Packing of spheres is boring, always hexagons, positions won’t flow easy, it’s rigid (diamond).
Instead using ovaloids (heavy) or small rigid sets of points (with maybe different radiuses) can generate flowing motion (like a fluid), no stable positions, more natural and irregular results.
Anyway, in this case/vase seems not ideal…
I am impressed by how far I got without Kangaroo. Though that’s enforced mainly by my lack of understanding how to use the plug-in. The colour jitter is cool! I am definately stealing that!
Hi eveyone. While I absolutely love the mathematical appporach of all the shown versions maybe a nice solution could be even easier. Just make a grid of points in equal distance and use it for orientation.
For a handmade weaving it might not work like this, but for a fake-weaving it looks quite cool.
That is essentially my very first solution “VR 1” with different bead size and rotation so that you can better see each bead. Your solution however cleanly contours the full height of the vase. Good job!
Perhaps the solution could be improved by finding an optimal bead size, so that you do not have to adjust these yourself. Or, even further, that the bead size and roatation is adjusted every row to an optimum.
Now that I am done you tell me you did the same before… I started when the workflow was already a bit more complicated. In any way it was fun to play with your file.
