3D Pattern onto Surface-Weaving Translation
Hello, Ive been very keen on being able to model a texture that resembles Jiseung (Paper Weaving) Korean tradition into a contemporary translation that will be applied to the interior of a theatre potentially. I looked into the different ways I can translate this weaving (rounded) language, and ive found a few references (Merav Gazit) which really is something I aiming to create on rhino but with the ability to control the roundness and flatness of the unit geometry. Ive tried with paneling tools but didnt achieve a result like the attached image below. If any of you have an idea or can point me to the right plugins or approach, i would greatly appreciate it. I highly value any and all of your ideas.
(Merav Gazit)
(screenshot from previous mcneel forum)
I’ve made quite a few surface modifications for 3D printing. Here’s an example that might be close to what you need: https://cults3d.com/en/3d-model/home/puffer1-1a
This is quite a long way from the interior of a building, but just let me know if you think it might work for you.
Make me think of something I did a while ago
Hello
quad remesh could be used
Not sure it is what you want, but here is an idea
If you have some curves on the vase that are separated by a distance (here 1). I use my Nautilus plugin clean overlapping curve.
2 ways of generating curves, polar array of construction curves (with some jitter)
or random flow
Then curves are cut by plane
Then on each point a plane is made an an object is oriented on this plane
weave points.gh (18.6 KB)
Has points are on a plane, you can then sort them by plane then by angle, so you can make a weaving curve by plane then pipe it.
This is just flexing Nautilus’ muscles, isn’t it?
Only thing left to do is make the curves follow a branching logic instead of using jitter to make it “appear” knitted.
I work with tools I know !
I think the quad remesh think is probably the best, the topology is there. Instant mesh gives more constant size quad, I don’t know if it is possible to to that with QuadRemesher
For the curve it was just an idea because here the main pattern is something that has a main direction, is cutted at constant height (length along curve indeed) …
Another way is that, look at the corn
Yes, well, since I am scared of math, I would have dealt with this more simply and regularly:
weave points VR 1.gh (39.2 KB)
Getting a venation is actually not that hard:
Getting that venation to express itself in some useful way is harder:
There are venation tools in Nautilus, correct? I did my best with native tools:
weave points VR 2.gh (53.4 KB)
It’s not so bad in a larger scale of knit. But you do have to look closer to see the orientation difference:
I am missing one “bead” where no point was made from an invalid line.
Very nice
No, but the only one I am after is something like the one done by Nervous System!
It might be interesting if someone with practical knowledge of knitting could describe how these knitted vases are created…
You can see the mismatch in the knots to make the pattern fit around the shape.
This can look unnatural when done algorithmically but less noticeable to the eye when done by a skilled knitter!
There was a publication about knitting using geodesic distance, they just use what I did on that subject but It seems it contains some valuable things about knitting
You basically skip stiches or double up on them is what it comes down to. That was the entire point of the venation, here without the branchings broken apart for separate polylines:
I find making the the skips in the columns algorithmically noticable is more the problem than the other way around! That’s what makes you recognize that it is knitting.
Are the pages that say “image not available” the ones where they stole your work?
I don’t think they stole my work. It is just a not free publication.
I misunderstood.
Yes, the venation looks great when its just lines but there’s something unpleasant about it when you put the knitted pattern on.
I wonder whether there’s some slight stretching of the overall fabric happening too?
Yes, pulling. The stiches will want to naturally be in columns, but the algorithm is simply connecting a node to the closest node the next rung up, resulting a in a zig-zig that would otherwise be much straighter. Also, you are right about the “skilled knitter” who would opt to place branchings further apart so they do not all occur in the same area. You can recognize this best from the bottom of the model:
where opposite the seam of the surface, the branching occur the most.
Already, just smoothing the polylines helps alot:
The result is that the stitchings are more columnar, but also that you get holes in the weave:
which draw your eye to where the branchings occur. That’s actually alot like what it is like in real life. Just a better branching scheme, and it’s looking pretty good. Or at least that’s as far as I’d take it.
Can you make the venation symmetrical around the vase? I like the look of the first top view but the right hand side is straighter lines. You smoothed polylines one looks more symmetrical but I think a symmetrical version of the first one could be cool. Not sure how you force the venation to be symmetrical though!
