I’m a complete beginner in grasshopper but I made this file to try and recreate a hammered texture across a 2m by 1m sheet, when I use less points and larger radius it works ok, but when I put the sphere radius to 15 (as I want it) and the number of points to 40,000 (a lot I know) the solid union has an error (Boolean union set is empty).
If anyone has any ideas on how to fix it that would be fantastic.
If you really want to make a model out of it, you could just bake the balls and substract them from a surface with this python script. It will skip the ones that fail to cut which you can then later manipulate manually. For better boolean succes, make sure your ball surface seam is out of the way (not part of the intersection) like this VoroniHammerTexture_sg.gh (6.9 KB)
main=rs.GetObject("select object to substract from")
subs=rs.GetObjects("select objects to substract")
for sub in subs:
new=rs.BooleanDifference(main, sub)
if new:
main=new
rs.Command("ClearUndo") #otherwise Rhino will become slower and slower with the process
