3 Text Dots in file, can only find 2?
When I do Ctrl + A, the commandline says I have 3 text dots
Bounding box shows me only a rectangle meaning all 3 must be in this area.
However, when I deselect them one by one I cannot find the third one. When I window select over the area it says I only have 2 Text Dots. Any clue what’s happening here? I will say that all 3 dots were generated from code.
231221 3 Dots.3dm (35.3 KB)
One of them is invalid:
Rhino text dot object is not valid.
ON_TextDot::CenterPoint() is not valid
That’s why it does not show up. Delete the two visible and then do a SelAll and then What.
Geometry:
Dot
Primary text: 0g
Secondary text:
Center point: (-1.23432e+308,-1.23432e+308,136.851)
Height in points: 14
Font face: Arial
Note the XY coordinates… It’s at minus infinity in X and Y.
Thanks for checking @Helvetosaur. I realized it was a bug with my code, but am surprised that an invalid text dot is possible to be added to the document.
please mark as solved / above answer as solution - thanks.
