2 little things popped back up
hey Marlin,
a couple of things that you’ve sorted out in the past have shown back up (3-4 releases ago)
  1. ToggleOsnapPanelUnderCursor only toggles on… it won’t toggle off with a mouse button so you have to move the cursor off the panel or click the X for it to close.
  2. deleting in the popup command dialog doesn’t work unless you click in the field first.
as in:
run the _Arc command
type 2
press delete
nothing happens… the 2 should delete
thanks
I don’t think this ever worked as you describe. The macros attached to mouse buttons are handled when clicking in the main drawing window and not handled at all by the Osnaps window. The Osnaps window does not recognize mouse button clicks for extra mouse buttons.
This will be fixed in the next WIP release.
is there an archive of the old mac rhino forum anywhere?
we discussed this a few years ago… toggling off didn’t work but then i described the reasoning why it should and you agreed and made it work :smile:
Mouse button commands are reworked in the next WIP release and clicking a mouse button to run a command when the cursor is over the Osnaps panel will work.
great! thank you
both of these work in nov5 2014 build :thumbsup:
