Variable radius fillet issue
Rhino v4
Trying to make a variable radius fillet on the end of a pipe. Because of the location of the pipe seam the results are random. The top example works fine. The second example won’t allow me to got from tip to tip. I can go from tip to the seam from either direction.
Is there a way to move the seam to allow me to do what I need?
The SrfSeam command should help, but you can pick more than one edge to fillet, if you are using FilletEdge.
