Hi, I’m automating tasks of a program created in NET to Rhino, in the program I have to select a curve and that curve a number of points to then delete them, I’ve been looking for information about it but I’m lost, Can you give me a helping hand ?
PS is not a plugin for rhino, but an external program made in c # NET
I am not quite I understand what you are asking to do. Tell if this sounds correct:
1.) You want to select a curve.
2.) You then want to turn on the curve’s control points (or edit points).
3.) You then want to select some of these points and delete them, thus modifying the curve.
4.) All this from outside of Rhino, via ActiveX automation.
Does this sound correct?
If you don’t mind me asking, why does this have to be done from outside of Rhino? What is it that you are really trying to accomplish?
