Hi forum
I can remove curve ctrl points with the delete button, but it does not seem to work the same way for solidpts.
I am working with planar surfaces for this, so processing wise, Rhino should be able to handle this just as easily as with curves.
I know I can make the detour of using DupBorder, Delete and Planarsrf, but you understand that I would like to avoid that, unless there is a macro to incorporate this…
