R6 Select curve, control points show
Was I imagining this?
When you window selected multiple curves in the previous version of Rhino 6 all the curves / lines would show their points.
But since the most recent update you have to select them individually for the points to show up.
Thanks
I’m pretty sure it’s always been that you have to select them individually.
@ra_mull Try Rhino Options>Mouse
That’s where you can turn the feature on and off but it doesn’t influence if points are shown when multiple curves are selected at the same time or individually.
@wim You are correct…‘multiple’… .OK I need more coffee.
:zipper_mouth_face:
Thanks for the responses, must have been wishful thinking on my part.
