Select lines in one direction...how?
Hi, V5
I dont see this in the selection options.
How can one filter a selection to only grab lines in a certain direction ?
Steve
Hi Steve- here is a script you can try - Unzip, and drag and drop the rvb file onto an open Rhino- this will add the alias
SelParallel
SelParallel.zip (1.7 KB)
I thought that was REALLY fast scripting!
[but it turns out you wrote it SEVEN years ago] and there it is on your script page.
:smile:
Cheers Pascal,
I went for drag select and nothing, then click and that worked.
what does TwoPoint do, how does one use TwoPoint ? No CommandHelp with this,.
parallel to axis is useful as well :smile:
How can I use this to drag select a region and have lines within that eg on x axis selected ?
Steve
Here’s one for filtering - same process as before, this one adds
FilterParallel
FilterParallel.zip (1.8 KB)
