Hi!
How to scale the object to the specified percentage?
For example ! _Scale (Scale factor 5 percent)
THX
Hi!
THX
Scale factor 0.05
uncontrolled reduction
Well, typing in a scale value of 0.05 will scale it TO 5% of the original size, to reduce it BY 5% you would enter a factor of 0.95.
ok,
I understood.
factor 1 = 100%
factor of less than 1 will decrease, and the factor is greater than unity will increase
0.95 = 95%
0.05 = 5 %
1.05 = +5%
Thank you all
Аnother question
As the scale of the model:
x 12.36
y 12.25
z 5.91
TO
x 19.78
y 19.61
z 9.46
Use BoxEdit
Or ScaleNU.
if the geometry isnt complex and you dont like to play with Scale command, u can just simply turn on Edit point or use Component selection to move your object to whatever size you like.
If the scale is uniform and you have a “from” and a “to” size, you can enter a fraction on the command line.
When asked for the scale factor, type 19.78/12.36 for example.
You can do this for each individual x, y, z value if you use ScaleNu as well.
–Mitch
Thank you very much!
Today I learned a lot of interesting ways to scale
