The dialog doesn’t appear at all. I’ve been in and out of Rhino all day without any issues, updated to the new build two minutes ago. I’d love to give a better report, but it’s not a crash so I don’t have much to go on.
Execute RunPythonScript
Message bar echoes “Command: RunPythonScript”
Command seems to exit successfully, but no window appears.
It seems that if you know the build date simply requesting the file is enough. The EULA prohibits redistribution and McNeel doesn’t provide file hashes, otherwise I’d always share the old images I use to roll back when regressions like this occur.
I just downloaded the new Rhino Mac (wip_20140630). After installing IronPython (python20140630) I can run scripts, but when I try to generate a textile via the python script it does not create the txt file. I also don’t get any errors and I know that the script is woking correctly. Any ideas on how to fix this?
Thanks!
I just released a new python build (July 1, 2014) for Rhino that should fix some of the dialog related issues that you guys are seeing with the release from yesterday.
Did MessageBox() ever work on Mac? My experience was that pretty much all of the …Box() methods failed on Mac previously because they all call WindowsForms… I know Steve is working on getting this stuff going on the Mac side, but up till now, I have had to avoid all of these methods for Mac scripts.
MessageBox() has worked as long as I’ve been using it, which is almost >2 years by now and was fine until yesterday. I can’t recall which (if any) of the others worked, except that EditBox() definitely did not work else you’d definitely see a few EditPythonScript.py floating around…
Yep, MessageBox was probably the ONLY one that did work. I’m in the process of getting the other user interface pieces working, but it also involved a whole lot of rearrangement to code (which is why we are seeing some new bugs crop up.)
