I seem to recall that it worked before - now it fails with an exception message…
Did this break something, or is my memory faulty and it never worked on Mac Rhino?
–Mitch
–Mitch
Getting this here as well, though I can only find that I use EditBox. Which is not the same thing.
@Alain, can you look into this?
which version of Rhino are you running?
5.1 - 5B161
–Mitch
Can you delete
~/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/IronPython/settings/version.txt
before you launch Rhino?
Ahhh! Success! Thanks Alain!
The question is, will others have the same problem? Why did this happen?
–Mitch
Unfortunately yes. Internally we track the rhinoscriptsyntax python files separately form the plug-in and recently RhinoCommon got updated along with the python files but the plug-in version stayed the same. I’ll fix the issue right away.
