Is it possible to get a list of the Recent Files from the File
menu? I can read the values from the Registry but unfortunately those
values aren’t updated until the program is shut down. I wanted to make a
popup menu that would show the recent files list.
I don’t believe Rhino’s recent file list is available in any API - sorry.
Thanks for the info.
I wrote a little C# Plugin that does what I want. It reads the Registry at startup and then tracks the saved files internally.
Hi TJ,
FWIW, ( I’m not sure about the files opened in the current session)
The python script below, I have running at startup, finds the recent files in ‘Rhino.ApplicationSettings.FileSettings.RecentlyOpenedFiles()’
import Rhino
import os
def OpenFromRecentFolders():
if rs.DocumentName():
return
recent_list = Rhino.ApplicationSettings.FileSettings.RecentlyOpenedFiles()
paths=[]
for filepath in recent_list:
if filepath:
paths.append(os.path.dirname(filepath))
short_list = list(set(paths))
short_list.append('D:\\_WERK')
space = [' ']*len(short_list)
short_list = [a for b in zip(short_list,space) for a in b]
folder_open = rs.ListBox (short_list, "Select Folder to browse", "Recent Folders")
if folder_open :
Rhino.ApplicationSettings.FileSettings.WorkingFolder = folder_open
#os.system('run "'+folder_open+'"')
rs.Command('!_Open')
if __name__ == "__main__":
script_name = os.path.basename(os.path.realpath(__file__)).split('.')[0]
macro = '! _-RunPythonScript "{}"'.format(os.path.realpath(__file__))
rs.AddAlias(script_name,macro)
I stand corrected…
Awesome! Thanks for pointing me in the right direction. This is easier than what I originally was doing.
It also looks like it updates the list dynamically as you save files during the session.
