I have the following script which exports obj files, working well. However on export when I display the obj file I am getting holes in the meshes when displayed in webGL. I do not understand if I am simply decimating the mesh to much. They seem to appear rather randomly, but I understand I am using a one size fits all export which may not be ideal.
Regardless, I found if I create the mesh manually in the GUI I can then also select an option to fill all holes. This fixes the issue, but I would like to incorporate a fill all holes step in my export. I don’t understand at what point I would do this step. Do I need to write a script which adds the mesh to the Rhino environment to access the command? The command I found is FillMeshHoles: http://docs.mcneel.com/rhino/5/help/en-us/commands/fillmeshholes.htm when the mesh is selected.
The script:
import os
import scriptcontext
print "//export run started/////////////"
# this function via mcneel/rhinoscriptsyntax
#https://github.com/mcneel/rhinoscriptsyntax/blob/master/Scripts/rhinoscript/layer.py
def layerNames(sort=False):
rc = []
for layer in scriptcontext.doc.Layers:
if not layer.IsDeleted: rc.append(layer.FullPath)
if sort: rc.sort()
return rc
def GetDAESettings():
e_str = ""
return e_str
def GetOBJSettings():
e_str = "_Geometry=_Mesh "
e_str+= "_EndOfLine=CRLF "
e_str+= "_ExportRhinoObjectNames=_ExportObjectsAsOBJGroups "
e_str+= "_ExportMeshTextureCoordinates=_Yes "
e_str+= "_ExportMeshVertexNormals=_Yes "
e_str+= "_CreateNGons=_No "
e_str+= "_ExportMaterialDefinitions=_No "
e_str+= "_YUp=_No "
e_str+= "_WrapLongLines=Yes "
e_str+= "_VertexWelding=_Welded "
e_str+= "_WritePrecision=8 "
e_str+= "_Enter "
e_str+= "_DetailedOptions "
e_str+= "_JaggedSeams=_No "
e_str+= "_PackTextures=_No "
e_str+= "_Refine=_Yes "
e_str+= "_SimplePlane=_Yes "
e_str+= "_AdvancedOptions "
e_str+= "_Angle=70 "
e_str+= "_AspectRatio=0 "
e_str+= "_Distance=0.0 "
e_str+= "_Density=0.4 "
e_str+= "_Grid=0 "
e_str+= "_MaxEdgeLength=0 "
e_str+= "_MinEdgeLength=0.0001 "
e_str+= "_Enter _Enter"
return e_str
def GetSTLSettings():
eStr = "_ExportFileAs=_Binary "
eStr+= "_ExportUnfinishedObjects=_Yes "
eStr+= "_UseSimpleDialog=_No "
eStr+= "_UseSimpleParameters=_No "
eStr+= "_Enter _DetailedOptions "
eStr+= "_JaggedSeams=_No "
eStr+= "_PackTextures=_No "
eStr+= "_Refine=_Yes "
eStr+= "_SimplePlane=_No "
eStr+= "_AdvancedOptions "
eStr+= "_Angle=15 "
eStr+= "_AspectRatio=0 "
eStr+= "_Distance=0.01 "
eStr+= "_Grid=16 "
eStr+= "_MaxEdgeLength=0 "
eStr+= "_MinEdgeLength=0.0001 "
eStr+= "_Enter _Enter"
return eStr
settingsList = {
'GetDAESettings': GetDAESettings,
'GetOBJSettings': GetOBJSettings,
'GetSTLSettings': GetSTLSettings
fileName = rs.DocumentName()
filePath = rs.DocumentPath().rstrip(fileName)
arrLayers = layerNames(False)
def initExportByLayer(fileType="obj", visibleonly=False, byObject=False):
for layerName in arrLayers:
layer = scriptcontext.doc.Layers.FindByFullPath(layerName, True)
if layer >= 0:
layer = scriptcontext.doc.Layers[layer]
save = True;
if visibleonly:
if not layer.IsVisible:
save = False
if rs.IsLayerEmpty(layerName):
save = False
if save:
cutName = layerName.split("::")
cutName = cutName[len(cutName)-1]
objs = scriptcontext.doc.Objects.FindByLayer(cutName)
if len(objs) > 0:
if byObject:
i=0
for obj in objs:
i= i+1
saveObjectsToFile(cutName+"_"+str(i), [obj], fileType)
else:
saveObjectsToFile(cutName, objs, fileType)
def saveObjectsToFile(name, objs, fileType):
rs.EnableRedraw(False)
if len(objs) > 0:
settings = settingsList["Get"+fileType.upper()+"Settings"]()
rs.UnselectAllObjects()
for obj in objs:
obj.Select(True)
name = "".join(name.split(" "))
command = '-_Export "{}{}{}" {}'.format(filePath+fileType+"/", name, "."+fileType.lower(), settings)
rs.Command(command, True)
rs.EnableRedraw(True)
initExportByLayer("obj",True, False)
print "//export run ended/////////////"
