I opened the file I previously attached; a jpg file from the windows snip tool, and manipulated the color balance and black and white balance to see if there were curves for the graph-none found. I’ll run the test again and see what happens. Cheers, Rob
I ran the first benchmark (which I’ve previously posted) while “docked” to an Apple Cinema Display. I decided to run it again at home, with just the laptop screen, to see if it was different. I got a little bit better score, when not connected to the big Cinema display:
Here’s my score for an Nvidia GT 330M:
Holomark 2 v2,1,01 Beta RC 1 - Expires: 2014-5-15
Total Score: 8537
Total Runtime: 379.49 sec
GPU scores: 5920
GPU_01 - 70.80 fps - Cube 4 tests
GPU_02 - 16.00 fps - UDT Shape
GPU_03 - 27.90 fps - Wireframe
GPU_04 - 18.60 fps - Shaded
GPU_05 - 12.40 fps - Rendered
GPU_06 - 11.80 fps - Block Rendered
GPU_07 - 8 units Nurbs @ 5 fps in Wireframe
GPU_08 - 5 units Nurbs @ 5 fps in Shaded
GPU_09 - 11 units Nurbs @ 5 fps in RenderSpeed
GPU_10 - 24.30 fps - RenderMesh Render
GPU_11 - 43.10 fps - RenderMesh RenderSpeed
GPU_12 - 13.30 fps - JoinedMesh Render
GPU_13 - 42.20 fps - JoinedMesh RenderSpeed
GPU_14 - 2 units mesh @ 15 fps in Shaded
GPU_15 - 1 units mesh @ 15 fps in Render
GPU_16 - 6 units mesh @ 15 fps in RenderSpeed
GPU_17 - 8.60 fps - mesh in Rendered Studio
GPU_18 - 3.80 fps - Nurbs in Rendered Studio
GPU_19 - 5.70 fps - Block Illustration
GPU_20 - 33.30 fps - 2D single
GPU_21 - 2.80 fps - 2D massive (20x)
CPU scores: 2617
CPU_01 - 24.22 sec - Booleans and Contours
CPU_02 - 3.14 sec - Twist and Taper (UDT)
CPU_03 - 9.87 sec - Meshing Mini
CPU_04 - 0.05 sec - Extract Render Mesh
CPU_05 - 0.12 sec - Join Render Mesh
CPU_06 - 109.11 sec - Reduce Mesh
CPU_07 - 34.70 sec - Calculating Technical display
CPU_08 - 9.81 sec - Making Silhouettes
Acer
Aspire 5745G
NVIDIA GeForce GT 330M - 1024.0 MB
DriverVersion: 9.18.13.3221
Intel® Core™ i7 CPU Q 720 @ 1.60GHz
NumberOfCores: 4 NumberOfLogicalProcessors: 8
MaxClockSpeed: 1.6 GHz
The time of technical drawing is 20 times the average of the data reported so far.
I feel that I have to buy a new computer.
Thank you Holo for having made available this test.
Ciao Vittorio
I am interested in the Quadro K5000, and I am wondering which Motherboard and CPU would give me the best compatibility and performance. Also does the K5000 require a PCIE 2 x16 slot only?
Greg
I am not sure that I have it set up correctly, but here is the entry level Nvidia Quadro K600 (almost a handful).
This one has the AA set to 8.
Greg
HoloMark2-01-K600.txt (1.9 KB)
Here is the same test on the same GPU and CPU with the AA set to NONE.
HoloMark2-02-NOAA-K600.txt (1.9 KB)
About 3000 difference!
Greg
It is obvious that AA requires power, and that it only represents 20% extra load is not that bad.
If you look at your scores you’ll see that many of the tests are not much affected. There the CPU / Rhino is the bottle neck. While the fast ones that already have really high fps are limited by the GPU so those are affected by the AA too.
I am surprised to see that you got so low scores at GPU_21. That I never would have guessed with the K600! Really surprising, as your CPU is great.
Also I was really surprised that your GPU_14 went DOWN from 12 to 4 when you turned off AA… That doesn’t make sense at all.
Hi Holo,
Here is another with the AA set to Zero, and the CPU set to maximum (as opposed to Normal)
Regards, Greg
Thanks John,
Reverted back to the older driver and got pretty much the same resultHM2_STE_050514.txt (1.9 KB)
Your CPU might limit the scores a bit, but it should not affect it too much.
Here are my Quadro 4000 scores, as you can see my i7 950 gets similar scores to your CPU.
About a year ago I was frustrated with the Q4000 and experienced with different drivers, clean-uninstalled an all. Nothing changed, until I clean uninstalled Rhino 5. Cleared out all reg entries from earlier V5 betas etc, and that sped it up with about 20%, but I have no idea why.
Here’s my old - but trusty - Dell macine. Actually surprised that it got above 20K score, since the graphics card is so old/slow, but I guess the CPU still packs an OK punch.
When I type Holo it finds the command Holomark2 but nothing is happening. Any clue?
Piotr
Holo,
Thank you for the great benchmark and support. I will run this new improved version again on this system and report back with the results. In the meantime here are the results from my laptop
EDIT: Above I was referring to run the benchmark on the Dell T7610 system with dual Intel Xeons that had not issues with UDT
Please do this:
Type Holomark2 and hit enter.
Then hit F2 and copy - paste everything from “Holomark2” here.
Thanks
Command: Holomark2
Command: _CommandHistory
No action at all.
P
