Dimension Aligned "DimAligned" in Rhino common
We know the Linear dimension works as below.
If I want to Align the dimension to the object, i mean Rhino Command “DimAligned”
How to implement it in RhinoCommon. I could not find anything in rhinoCommon for DimAligned
The below code only serves as command name “Dim”
I am looking for “DimAligned” code in RhinoCommon…
Point3d origin = new Point3d(1, 1, 5);
Point3d offset = new Point3d(110, 120, 90);
        Line line = new Line(origin, offset);
        doc.Objects.AddLine(line);
        //Point3d pt = new Point3d((offset.X - origin.X) / 2, 3, 0);
        Point3d pt = new Point3d((offset.X + origin.X) / 2, (offset.Y + origin.Y) / 2, 0);
        Plane plane = Plane.WorldXY;
        plane.Origin = origin;
        double u, v;
        plane.ClosestParameter(origin, out u, out v);
        Point2d ext1 = new Point2d(u, v);
        plane.ClosestParameter(offset, out u, out v);
        Point2d ext2 = new Point2d(u, v);
        plane.ClosestParameter(pt, out u, out v);
        Point2d linePt = new Point2d(u, v);
        LinearDimension dimension = new LinearDimension(plane, ext1, ext2, linePt);
        dimension.Aligned = true;
        if (doc.Objects.AddLinearDimension(dimension) != Guid.Empty)
            doc.Views.Redraw();
            return Rhino.Commands.Result.Success;
        return Rhino.Commands.Result.Failure;
A DimAligned is just a Linear Dimension with an aligned Plane. What happens if you align your plane? In this image, the dim on the left is a linear dimension, the one on the right is an aligned dimension. Notice their construction planes. A linear dimension has the same plane orientation as the current viewport cplane, an aligned dimension takes on the orientation set up when the user picks the dim points. Maybe create a Plane with the x axis in the direction of the Line in your code?
Thanks a lot ! Yes, very good point. I could not think of it. So wrote myself something(custom DimAligned) by vector calculation last 30 minutes.
But if I follow your way, it will be much easier than mine…
Many thanks !
I tried in different ways to align the dimension without succeeding.
The problem is that the dimension is rotated and is not parallel to the measured line.
        Point3d origin = new Point3d(1, 1, 0);
        Point3d offset = new Point3d(110, 120, 0);
        Plane plane = new Plane();
        Vector3d vx = vector3d(origin, offset);
        Vector3d vy = Vector3d.CrossProduct(vx, Vector3d.ZAxis);
        vx.Unitize();
        vy.Unitize();
        plane.XAxis = vx;
        plane.YAxis = vy;
        plane.ZAxis = Vector3d.ZAxis;
        Point2d ext1 = new Point2d(origin.X, origin.Y);
        Point2d ext2 = new Point2d(offset.X, offset.Y);
        Point2d linePt = new Point2d(pt.X, pt.Y);
            doc.Views.Redraw();
        return Result.Success;
Domanda25
If you could help me I would be very grateful.
Matteo
Hi @matteo.forlani.90,
Are you using Rhino 5 or 6?
– Dale
Rhino 5.
Here is a sample that works in Rhino 6:
It may no be possible to create an aligned dimension in RhinoCommon in Rhino 5. Some of the dimension classes were incomplete.
– Dale
The method “L.Dim.create” doesn’t exist.
Yes, as I mentioned the sample works in Rhino 6.
– Dale
Hi @matteo.forlani.90, below works in Rhino 5, you may want to try to convert this from python to C#:
import Rhino
import scriptcontext
def DoSomething():
    p0 = Rhino.Geometry.Point3d(0,0,0)
    p1 = Rhino.Geometry.Point3d(10,5,0)
    pd = Rhino.Geometry.Point3d(11,9,0)
    plane = Rhino.Geometry.Plane(p0, p1, pd)
    if not plane.IsValid: return
    rc, s, t = plane.ClosestParameter(p0)
    start_pt = Rhino.Geometry.Point2d(s,t)
    rc, s, t = plane.ClosestParameter(p1)
    end_pt = Rhino.Geometry.Point2d(s,t)
    rc, s, t = plane.ClosestParameter(pd)
    on_dim_pt = Rhino.Geometry.Point2d(s,t)
    dim = Rhino.Geometry.LinearDimension(plane, start_pt, end_pt, on_dim_pt)
    if not dim: return
    dim.Aligned = True
    dim_id = scriptcontext.doc.Objects.AddLinearDimension(dim)
    if not dim_id: print "Error adding aligned dimension"; return
    scriptcontext.doc.Views.Redraw()
DoSomething()
_
c.
It works!!! :grinning::grinning:
