BUG MatchObjectAttributes
Hi All,
I wanted to point out a potential bug when using rs.MatchObjectAttributes() .
srcId = rs.GetObject('pick source')
targetId = rs.GetObject('pick target')
rs.MatchObjectAttributes(targetId, srcId)
Whilst all attributes are copied from srcId to targetId, User Strings are completely removed from srcId object in the process.
The implementation of rs.MatchObjectAttributes should probably look more like this:
def MatchObjectAttributes(target_ids, source_id=None):
    """Matches, or copies the attributes of a source object to a target object
    Parameters:
      target_ids = identifiers of objects to copy attributes to
      source_id[opt] = identifier of object to copy attributes from. If None,
        then the default attributes are copied to the target_ids
    Returns:
      number of objects modified
    id = rhutil.coerceguid(target_ids, False)
    if id: target_ids = [id]
    source_attr = scriptcontext.doc.CreateDefaultAttributes()
    if source_id:
        source = rhutil.coercerhinoobject(source_id, True, True)
        source_attr = source.Attributes.Duplicate()
    rc = 0
    for id in target_ids:
        id = rhutil.coerceguid(id, True)
        if scriptcontext.doc.Objects.ModifyAttributes(id, source_attr, True):
            rc += 1
    if rc: scriptcontext.doc.Views.Redraw()
    return rc
http://mcneel.myjetbrains.com/youtrack/issue/RH-29590
That’s the one!
Hi Dale,
It says "No module named utility"
my script is as follows
import Rhino.Geometry
import Rhino
import scriptcontext
import utility as rhutil
import System.Enum
import math
thanks
If you remove:
Does your code run?
Hi Dale,
It says
Message: global name ‘rhutil’ is not defined
Thanks
Without the code that does not work, we’re not going to get very far…
If you are trying to use the above in your own code, then use this:
def MyMatchObjectAttributes(target_ids, source_id=None):
    Parameters:
    Returns:
    id = rs.coerceguid(target_ids, False)
    if source_id:
        source = rs.coercerhinoobject(source_id, True, True)
    rc = 0
        id = rs.coerceguid(id, True)
            rc += 1
    return rc
Thanks,thats great
