Equivalent rs.MatchObjectAttributes in RhinoCommon?
What is the simplest way of copying all attributes from one object to another with RhinoCommon ?
I tried the following (with Python), but it seems not to produce any change:
import Rhino
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt("Select first object")
go.Get()
object1 = go.Object(0).Object()
go.SetCommandPrompt("Select second object")
go.DisablePreSelect()
go.Get()
object2 = go.Object(0).Object()
object1.Attributes = object2.Attributes.Duplicate()
Hi @felix.mariotto
import Rhino
# Get the first object
go.Get()
# Get the second object
go.Get()
# Copy attributes from object2 to object1
# Commit changes
object1.CommitChanges()
You must commit the changes in order for the attributes to update
Hope this helps,
Farouk
Thanks a lot Farouk, this CommitChanges is what was missing !
