Zbrush Color Material
Does anyone happen to know which Rhino material color closely resembles ZBrush’s default material?. Thank you!
open both zbrush and Rhino then use the rhino eye dropper to sample that color-
or sample the color in photoshop and get the rgb values…then simply plug them into a rhino plastic material and adjust the reflectivity and gloss till you get what you want
Thank you for your prompt reply. I do not own ZBrush or Photoshop. Currently, I am using only Rhino 8
ok, you’d need to know the rgb values of the zbrush material to have any hope of duplicating it.
From ChatGPT (can’t corroborate at the moment):
Default material is MatCap Red Wax. Its RGB color values are approximately:
• R: 255
• G: 64
• B: 64
This can vary slightly depending on lighting and shading in the viewport. The material itself has embedded shading info (MatCap), so the visual effect isn’t just from RGB color alone.
