Hi all,
i need to determine in wich direction is oriented my cplanes Z axis
For example, i set a cplane on planar curves with Rhino.curvePlane.
on pictures we have 2 similar curves, but one put the Cplane Zaxis upside the other.
in script, arrPlane (3) return the Z axis, but i got a vector value, with 3 index, sometimes positive or negatives value depending of curves placement.
How can i determine the direction of my axis with these values ?
or may be another solution ?
Thanks.
Call Main()
Sub Main()
Dim strCrv, arrPlane
strCrv = rhino.getObject("Curve", 4)
arrPlane = Rhino.CurvePlane(strCrv)
Rhino.ViewCplane, arrPlane
End Sub
If you use the Dir command, you will notice that the directions of the two curves do not match. A planar curve whose direction is counter-clockwise will have it’s plane normal facing upwards. Likewise, a planar curve whose direction is clockwise will have it’s plane normal facing downwards.
Yes, i already tought to use Rhino.ClosedCurveOrientation to check curves direction, but i also use open planar curves , and i can’t use this method on open curve, that’s why i tried to determine cplane Z axis direction made by Rhino.curvePlane.
