X-Ray tool
Some experiments to make sort of X-Ray images, indeed It outputs distance
Reference Engine from Artec /Renault
from
Armadillo
Very cool. Could you explain the process a bit more?
I first define a screen (radiographic film), I have a tool for that
You input objects, a direction, and pixel size in X and Y. This tool outputs two planar meshes that represent a film with pixels.
Then I throw ray along the meshes and I look if segments of ray are inside or outside (for a volume) and I sum the distances
If object are surface I have a default thickness that I add each time there is an intersection
As I output distance it is also possible to use real attenuation for X ray, so it could be possible to mimic better Xray looking.
clever! Thank you for the break down
It uses that
https://developer.rhino3d.com/api/rhinocommon/rhino.geometry.intersect.intersection/meshline
Interesting!
It seems you picked the darker area of the picture and set that for bound-limit 0-1 greyscale for the rest the picture. Maybe adding a fixed threshold would give a more constant appearance to objects.
In your video it seems the torso is changing thickness depending on the camera angle…
… will this be part of Nautilus?
Indeed I didn’t make lot of effort on this, because max distance change depending on the angle. Yes I must have used a threshold or an attenuation Law (exp(-lambda*distance)). to make realistic images.
Yes it will be in Nautilus along Thickness Analysis. But here I have some Gradient problem doing the same as in Rhino
Now my tools outputs the same color as Rhino
Cool stuff!
I think that a volumetric representation (and its mesh) would be a good addition to Rhino. 3D meshers are out there. Oddly, CF-Mesh (free/shareware) (cfmesh) merely makes truncated cubes, but the magic is that it runs reliably. Tetgen’s/Negen’s unstructured mesh can make some beautiful meshes, but OpenFoam complains about their “badness.”
That stated, Rhino’s Quad-remesh, makes some good looking structured surface meshes, and would make a good basis for a 3D mesh (nudge). One of the hardest parts of solving–is getting a good mesh.
Paraview (free as in beer) has a good volumetric visualization. It might be able to do its own tetrahedrialization.
If you knew the present camera normal, an object may be sliced depth-wise. The pieces could be given a translucent material.
Nice and professional works :slight_smile:
hello! is there any way you could share the tool used to get screen from object. As well as the radiation tool.
thanks!
Hello
this is in 1.9.7 version, available in Package Manager
At the moment Xray is in paid version
Xray_licence.gh (9.8 KB)
Evaluation licence to put i same directory as LDLIB.dll or one directory upper (better i you use package manager)
NautilusLicencesEvaluation.xml (13.9 KB)
X ray around (it uses the screen normal for the direction of Ray
XrayAround_licence.gh (10.6 KB)
Thickness Analysis is also there
Thickness Analysis.gh (7.6 KB)
Making some carbonite looking
Thickness analysis using Rhinocommon tool
xray image.gh (13.7 KB)
xray carbonite.gh (13.7 KB)
Thickness Analysis to sphere.gh (21.0 KB)
Do you ever do any projects that aren’t impressive @laurent_delrieu? :smiley:
This is just for fun.
For real work I do that : Floor heating tool (very hard to make it bulletproof !!!)
and that tool for surf core structure (quite hard to use Mesh/Brep from Rhino so I ahve to use Dendro !)
Looks great!
