Working with xml GPX data in Grasshopper: Z axis not responding
I have a GPX file with X, Y and Z data. I use a sonic text search to extract a list of lon(gitude) and lat(itude) points. The XML reader doesn’t seem to read inside element attributes.
I used the XML reader directly to extract the ele(vation) points.
The X Y Z data points to a construct point battery. X Y Z all have 1009 indexes. Why is the Z axis not responding?
231026 Tiergarten VDIST and SOUND reader_Re.gh (62.5 KB)
That’s not really an invitation…
Can you share the *.gpx file?
Hi Martin,
thanks for your response. It says I’m not authorised to upload a GPX.
I found a solution - the Z being cancelled out by the mosquito plugin.
Ok.
FYI: You can always create a zipped folder of a file…
