Wishlist rs.ExtendCurveOnSurface()
Hey,
It would be great if we could get the ExtendCurveOnSurface function implemented in rhinoscriptsyntax library.
I have worked up an example using Rhino.Geometry and it seems to work fine for me. The rs.coercecurve would need to be changed to rhutil.coercecurve and some if/elifs for selecting which end to extend but the core functions all seem to be present for this to be added.
import Rhino
from scriptcontext import doc
def ExtendCurveOnSurface(Crv,Srf):
    Surface=rs.coercesurface(Srf)
    Curve=rs.coercecurve(Crv)
    Extended=Curve.ExtendOnSurface(Rhino.Geometry.CurveEnd.Both,Surface)
    if Extended!=None:
        doc.Objects.Replace(Crv,Extended)
        doc.Views.Redraw()
Thanks,
5chmidt
Hi Peter,
I’ve added this to the wish list for V6.
Has this been implimented in V6 as I cannot find it .
No. It is currently on the “Future” list: RH-26627
Doesn’t look like it, no,. Neither in VB Rhinoscript nor Python rhinoscriptsyntax.
However, it is available in RhinoCommon, so a python function could be written to emulate it:
https://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_Geometry_Curve_ExtendOnSurface_1.htm
Here is a bit of sample code (obviously more/better UI could be added):
import scriptcontext as sc
import Rhino
def ExtendCrvOnSrf(crv,crv_end,srf):
    return crv.ExtendOnSurface(crv_end,srf)
def ClosestEnd(crv,pick_pt):
    #determines the closest curve end to the pick point
    dom=crv.Domain
    rc,par=crv.ClosestPoint(pick_pt)
    if rc:
        start_len=crv.GetLength(Rhino.Geometry.Interval(dom.T0,par))
        end_len=crv.GetLength(Rhino.Geometry.Interval(par,dom.T1))
        if start_len<end_len:
            return Rhino.Geometry.CurveEnd.Start
        else:
            return Rhino.Geometry.CurveEnd.End
def TestFunction():
    crvID=rs.GetObject("Select curve to extend",4)
    if not crvID: return
    srfID=rs.GetObject("Select surface that curve is on",8)
    if not srfID: return
    pick_pt=rs.GetPointOnCurve(crvID,"Pick end of curve to extend")
    if not pick_pt: return
    crv=rs.coercecurve(crvID)
    srf=rs.coercesurface(srfID)
    #determine if pick point was closer to start or end
    crv_end=ClosestEnd(crv,pick_pt)
    if crv_end:
        ext_crv=ExtendCrvOnSrf(crv,crv_end,srf)
        if ext_crv:
            sc.doc.Objects.AddCurve(ext_crv)
            rs.DeleteObject(crvID)
TestFunction()
Thanks very much for your help this will keep me progressing, nice to see the proper VB script eventually though.
