[WISH] Wrap text in Command Window
In Rhino 8, it is possible to detach the Command window from the full-width interface and relocate it as any other panel by changing this advanced option:
This opens more possibilities for the layout, such as this (Command Window on the bottom-right):
Unfortunately, as you can see if you squint on the bottom-right corner, the text in the Command Window does not wrap, and no horizontal scroll bars appear. To view the text, one must click and drag with the mouse all the way to the end of the line.
Would it be possible to change this behaviour in future versions of Rhino (I feel like wrap behaviour should be the default)? Or am I missing an option that makes it possible already in the current version?
Hi Alessio -
That seems to be wrapping here:
I see that you are running _ReadViewportsFromFile - but that should just pop up a Windows Explorer dialog, and doesn’t offer a “Browse” option when I try that here…
Hi Wim,
This is on a newly opened Rhino instance (no wrap, as you can see):
The command is run as a part of an alias to import a 3-viewport custom arrangement from a template file. In the alias, the command is followed by a string with the full path to the template file.
Addendum: it seems the wrap occurs in the Command Line, but not in the Command Window. Here I have tried with the SetObjectDisplayMode command:
Hi Alessio -
Thanks. I see this in Rhino 8 as well. This works fine in Rhino 9:
Can I hope for a fix in Rhino 8?
Hi Alessio -
No. The commandline is being rewritten using cross-platform code to enable the same UI on both macOS and Windows. When I switch to the “legacy” code in Rhino 9, the same non-wrapping behavior is also present there.
