Wish - Power units for native Rhino lights
Native Rhino lights only have a unitless number. With todays render engines we should be able to specify the power units for lights (at least in watts or lumens). Efficacy is also a good value to have.
The Blender interface uses Watts as the default unit.
Clipboard-1
I agree that we should be able to set lighting by physical units rather than by a dimensionless number.
Watts are a measure of the amount of electricity consumed by an electric light source, but the amount of light emitted per watt varies from one device to another, depending on its efficiency, so watts are not a good way of setting lighting values. Dimmable lights make them even less desirable.
Lumens are a measure of the amount of light emitted and therefore allow direct comparison of one light source to another. Lumen levels are commonly provided by lighting manufacturers. Lumens are used in lighting calculations to derive Lux, the amount of light per unit area which is used to define task-based lighting requirements. Please make Lumens the measure of light emission!
Rhino.Geometry.Light has had PowerCandela, PowerLumens, and PowerWatts properties for at least half a decade, but as far as I know they are just not yet used anywhere, and there is no way to say which would be active at any given time, if they were. So that’s a start, anyway … now let’s just hope they get hooked up to things at some point.
Modernizing the light system can help with interoperability between render engines.
I made sure this is logged: RH-80011 Use power units for native rhino lights
