WISH: include SubD in Dynamic Geometry Pipeline component
Could there be a new release of Human and include SubD object in Dynamic Geometry Pipeline? I did come across situations that I need to reference multiple SubD objects.
You might say that I can reference mesh objects with Dynamic Geometry Pipeline and turn them into SubDs, but still mesh is not capable as SubD in these known aspects:
  1. creasing features are hard to adjust in GH;
  2. Mesh class does not support Ngon as good as SubD, for example, using stitch command to edit mesh can destroy all Ngons within, while with SubD, polygon faces do not change.
Dynamic Pipeline is native in Params, you should therefore change the category from Human to Grasshopper
Yep, SUBD is missing.
_ExtractControlPolygon
or as Macro
_ExtractControlPolygon _Pause
_Hide
in conjunction
DP
returns same SubD object
He’s talking about Dynamic Pipeline from Human. Your screenshot is the native Geometry Pipeline. This is the appropriate category.
As for the original question, it’s a good idea but I am unlikely to make any changes to Human any time soon. I am more or less retired from GH plug-in development.
Normally yes, but you have repeated it a thousand times, You will no longer maintain Your Human plugin.
Thus, a WISH in this category is obsolete and that is why I prefer to change category.
Regards
:sob:
:crying_cat_face: Sad to know that, but still can’t thank you enough for the Human plug-in, which really defined the proper workflow for Rhino in the building industry.
Bumping this thread as I’d love to ingest a SubD into a workflow using either the built in geometry pipeline or Human plug-in version—I’m trying to take a relatively low-poly SubD source and then convert it to meshes at various subdivision levels for various downstream operations. Having to pre-process the SubD out as a separate series of operations first and manually sort them out as meshes onto their own layers to re-ingest into the definition (or update reference selections manually) is less ideal.
