WISH: Extend Srf
I have to say they almost always answer me. Occasionally no … Patience!
They will be busy with more important work …
The development and support team is excellent!
This command improves more and more!
The extension of trimmed edges should be improved and the possibility to extend more than one edge at a time. In this way the command would be complete and really powerful.
I don’t know how the command evolved in Rhino 7 wip…
I hope it doesn’t remain the same as the one seen in v6. It would be a welcome surprise if more than one edge could be extended at the same time, useful in the case of angular edges, such as those in the photo (the pentagonal tubing cannot be extended, except by exploding the surfaces and extending them one by one: too laborious; same what for the flat surface … I understand that the two cases are different, the tube is a polysurface, the other is a simple surface, we should find a common way that combines the two instances…:thinking: ).
I hope Rhino 7 is not just SubD, but also focuses on some “shortcomings” of past versions!
