When using the convert command to convert splines or arcs to polylines, I would like to have an explicit point count control. This is useful for cases where you need a certain resolution (e.g. I needed four points to convert a fillet arc, but with the tolerance options I could either get 3 or 5.
Not sure how Convert will hold the tolerance with that input… but if you just want to “convert” an arc to a polyline with X number of points, just use rebuild with degree 1 and X points.
Use Rebuild with Degree of 1 and Point count as desired.
Hadn’t thought of that, good idea.
