(WISH) Cluster with (Type / Access) Signature
Script Components allow to set input Parameters with “Type Hint” and “Access - Item - List - Tree”.
Which allows a proper Signature of the Component.
Definitions that are set up for Hops (or Grasshopper Player) have Type specific “contextual inputs” that allow Tree Access = True/False.
Cluster Inputs (implicit) inherit the Type from the first wire.
(This is why I teach to have single connection / wire to a Parameter-Component inside the cluster first.)
But for more complex clusters it is nearly impossible to develop them isolated / in a separate file - and predict the behaviour, if the inputs change their type or structure.
I really would love to see an option, to explicitly set the Type and Access for Cluster Parameters.
With the result, that the standard, grasshopper combinatoric logic is applied to the Cluster the same way it is applied to a standard component.
This would allow a proper isolated development of clusters.
@fraguada dear luis - still would love to see this feature. not sure why this topic did not get much attention. who s the right person to discuss this ? you ?
thanks for having a look.
is my post clear enough - do I need to clarify things ?
thanks - kind regards -tom
I am certainly not the right person for this request. Your request is very clear, but the solutions are not. Certainly this is not something we would look to do in GH1, so it is probably best to bring this up in the context of GH2, where clusters have not yet been tackled in earnest. Please correct me if I am wrong @DavidRutten.
@rajaa
@eirannejad
@martinsiegrist
would love to see your comment on this topic.
This sounds like a good idea.
The lack of type and access info is one reason why I avoid clusters.
Especcially the level access definition would be very interesting, It could make for a completely new way of dealing with datatrees!
@DavidRutten
as I see you active on the forum just now - did you have had a look at this topic ?
thanks for your thoughts / comments / initiative
tom
