Years ago, I proposed implementing of “Time of last modification” property to every type of object, so that the user could get a better idea which object is newer and which is older. Obviously, if a new object is not yet modified, the “Time of last modification” will be also the time of its creation. This could be especially useful in case that there are nearly duplicate surfaces with minor improvements on each iteration. ![]()
The expectation is that all newly created object in the future Rhino will have their unique “Time of last modification” (a value that could be updated upon every future modification of the object itself) which is not dependent of the file’s own modification time.
Yeah I got that but I already posted and who knows maybe this could be scripted somehow?
The best way is to have that information coded in Rhino itself, which means that the Rhino developers must implement it as a default properties.
If it was a script, I imagine that a Dot object could be automatically assigned to each new object and update the time value upon every modification. However, that would add an unnecessary amount of dot objects in the viewport consisting multiple objects. ![]()
It could be Attribute User Text
So, it’s possible and just needs to be implemented soon. ![]()
Copilot said it can be done with an event handler. In my example the script runs and updates whenever an object is modified. It’s just a test… It seems as if the key value pair is added to new objects automatically. Not sure how that works
import datetime
import Rhino
def update_modification_time(sender, e):
"""Event handler to update modification time of objects."""
obj = e.ObjectId
if obj:
timestamp = datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S")
rs.SetUserText(obj, "ModifiedTime", timestamp)
# Register event handlers
Rhino.RhinoDoc.ActiveDoc.AddRhinoObject += update_modification_time
Rhino.RhinoDoc.ActiveDoc.ReplaceRhinoObject += update_modification_time
print("Modification tracking script is running...")
Wow, so fast. This only works withing the current session, but can’t be saved and updated automatically when Rhino and the file is opened again later?
I use a few commands that way in Rhino 7. So, if this is added to the list of initially running commands, the time stamp will be preserved for the next sessions?
I closed and opened the file. This is in the command line:
File created in Rhino 9 WIP
timestamp.3dm (73.2 KB)
timestamp.py (564 Bytes)
Maybe it would be better to switch the script on with a command instead of having it run automatically?
I don’t have access to Rhino 9 WIP, but I will make sure to test this when I buy it once it’s released.
Thanks!
timestamp_8.3dm (78.4 KB)
You can put the script into a button and run it as a macro.
Thank you. I will try it tomorrow in Rhino 8.
