Will Random numbers (with the same inputs) always be the same, no matter which computer/system/grasshopper version I’m using?
If you want a different set of numbers, you can change the seed input. You can use a seed based on the current time to get a different set of numbers each time you run your script.
Here’s a couple of examples:
-Kevin
not really, I need to know, if I sent the same .gh file to many people, would they have the same random numbers output, or is it dependent on software/hardware they use?
Hello
I don’t find the discussion but I think David Rutten said it was .NET random.
And I tested it, it is.Net random
See this script 20000 randoms, no differences
random NET vs GH.gh (8.9 KB)
https://blogs.siliconorchid.com/post/coding-inspiration/randomness-in-dotnet/
I believe the answer to your question is yes. With the same inputs to the Random component, they will get the same outputs.
I get the same results as @jaymezd on the MacOS version of Rhino/Grasshopper (with the same inputs).
-Kevin
