The break happens no matter the diameter.
WHY.3dm (980.1 KB)
there is a slight kink (G0) transition there, is it needed? if you can make it G1 it will probably work correctly
I can see the kink when I zoom in close to the original curve I rotated. I’m not certain I’ve completely wrapped my head around the G labels, but I’m getting there. How/where do I find that info about an object, and then change it?
Thanks. BlendCrv and trimming with the created blend worked.
