Which prog retains mesh for detail and simplifies for planar?
I need a prog that retains my triangles for the areas needing accuracy, nuts , bolts, switches, threads, holes, and simplifies the face count for planar and flattish areas.
I have looked at nBalancer and see elephants and horses,
not a good start.
have emailed them and got no reply.
I simply want something that is dead easy to work with, feed it the obj and have it churn out a much better mesh that wont cause Rhino to take 2 mins to save, or move.
Simple decimation is for rubber ducks !
I am with engineering items I need to reverse engineer.
Cheers
Steve
Steve, did you test the trial for nBalancer Pro? This is the best application outside of Geomagic for reduction and preserving detail. It is fairly easy to use. The Pro version allows a tolerance value to be entered, that’s the version you would need. Typically the file size can go down to 50%, but often can get to 25% or better of the original size without a loss of detail.
I had not heard back from them, however I have tried again and now have comms :grinning_face:
They have offered to show me what it can do,
I have sent two OBJ’s one taken with 17mm of a gun turret, nuts etc have form though not as detailed as 40mm, where the end surface of a locknut (internal substance) is evident !
Await to be impressed.
Both have details and also wavy bent metal damaged former flat or curved sheet, or still dead flat smooth aluminium. (the 40mm container)
Cheers
Steve
Sorry about the delayed response. I recall decimating a frame with tires that you provided a few years back as an example. The result was was not immediately usable because the texture did not display properly in Rhino. However, I was able to fix that in Rhino. Hopefully, I still have those files somewhere.
I had a PM exchange with you in September 2025.RE: Can Rhino handle mesh without being very slow? The files in the links are gone, but the discussion points have not changed. The V5 concern you mentioned appears to be the display fo vertex color, not texture map:
If you are using Shaded view setting you are seeing vertex color, not the texture map. It will be blurry because it does not have the details in the texture map. The color comes from the vertices of the triangles, rather than pixels in the texture map. Therefore the larger (and fewer) the triangles are, the less detail will be visible.
Only Rendered view will show the texture map.
The reduced mesh I saved does not have vertex color, so Shaded view will only show a single color for the mesh.
In Rendered view, you can reduce the darkness of the shadow or eliminate it in the Render display options. This will not affect shadows that were captured when the photos were taken.
